Oh jeez.... not that again....
HHO is well pointless BS, it's the snake oil of engine fuel additives (as useless as can be)
stan meyers of all... yeah [sarcasm] he was killed by the fossil fuel mafia[/sarcasm]
Jeez as if you switch your brains off while watching yt videos.
what next.. GEET? I swear I will vomit!
... and was fascinated by the challenge to dial up a resonant frequency to "split" pure water rather than using brute force amperage and drain cleaner as many electrolysis generator builds.
You MUST be joking right?
resonating frequencies huh.. any idea what frequency you are targeting to do that?
Any idea what Amplitude you are looking at to actuall transmit the required energy?
Any idea how much power and control you would need to feed into your wave generator to gain even the tiniest effect?
There is no easier and more efficient way to split water back into hydrogen and oxygen
than with 'simple' electric power.
drain cleaner is a bit of a nono.. way easier/cheaper to just use table salt (less toxic too)..
Or frankly just use sea water instead, there's plenty around and it's freely available as well.
But be sure to dial in the process properly..
else you might end up making SODIUM HYPOCHLORITE (a nice homemade sanitizer)
but not exactly a good engine fuel
ideally one's smart enough to ONLY collect the hydrogen though..
it's an anode cathode thing.. HHO believers are unable to figure that out though [since you find it in a school book]
the oxygen only adds volume for nearly no additional benefit, the air around has more than enough oxygen to combust the hydrogen.
(exception: submarines and space vehicles... bring your own oxygen.. but be sure, noone would build an HHO submarine or shuttle anytime soon)
in general hydrogen powered vehicles are a thing!
(for perfectly good reason)
Now it's on you to find out why no known entity
(no university, no car manufacturer, no boat maker, noone that ever produced some commercially successful product or the idea for one)
cares to use HHO...
PS man I'm sick of those flat earth - free energy babble
PPS that topic is terribly misleading.. hydrogen: "yeayyy go on..." HHO: "oh shut the fraud up and leave me alone with that BS"
[means: topic corrected]
