miniblazinbmx
New motor, new build, 18hp Duromax 440cc
stainless header
stage 1 air filter pod
stock governor
stock EPA carb (non-adjustable)
choke on-starts/idles and puffs a little black smoke at times..
half choke-runs better/idles better, revs out but backfires..
choke off-idles, and sputters and dies with any throttle..
idle screw doesn't seem to change much. no vacuum leaks..
Is it running rich? and if so how is possible to run richer after adding better air/exhaust? Would it not be the other way around i.e. running lean??
going deeper, Ive got a 42 and 43 main jet here and my stock is considerably larger, maybe closer to a 45 or 46 but it isn't labeled. the e-tube is massive, I've not gotten the pilot screw out to check yet..
Ive got a vegas carts 24mm bored here that needs jetting, and also with closed off adjusting screws.
and Ive got a 34mm slide carb that wont work with the stock governor(probably a stage 2-3 upgrade part).
So, I need to know some ideas where to start as far as jetting and making adjustments, even if it means I have to buy a $20 ebay adjustable carb, or modfiy this vegas one to start. (The company that makes that carb is actually ARC racing just fyi).
The kart runs but having a carb that isn't adjustable while making upgrades is maddening.. I appreciate any and all reasonable advice and suggestions.
stainless header
stock governor
