BrianSlaughter3355!
- Messages
- 22
- Reaction score
- 0
O.k I have a predator 212 non hemi block with a hemi head stock crank gov. Removed, super x cm grind cam, +.02 billet rod, flat top piston, 22lbs springs, billet fly wheel, stock hemi push rods and rockers, and mikuni vm22 26 mm carb. I just moved everything to a new block bc of hole in cylinder wall but I was having same issue before transfer to new block issue is it will crank and run for a few seconds then quit or if you try to give it throttle it quits either way gas is new gas tank is home made with vent oh lash is set at .003 sparkplug is a racing plug and I'm lost any ideas or suggestions would be greatly appreciated
