Role
Nobility
The engine on this go kart is an automatic w/ reverse 110cc 4 stroke. I noticed the engine rpm is reving too high before catching, even with weight of 150lbs 2 kids (says max load is 289lbs), so it definitely should not be dragging like this.
So, the clutch could have crystallized and need to be replaced. However, I've read you can adjust the the screw outside the cover to get a little more clutch.
I know I have to loosen the nut and then turn the bolt screw one way or the other, however, I'm not sure which direction and how much?
Same ole principle of "lefty loosey, right tightey?"
I couldn't find any actual video tutorials or someone showing the simple steps involved.
Any help is "ALWAYS" appreciated!
