Hello
8BallBass
Hello everyone
Im a new member just saying hello and letting everyone know that i love mechanical things and i want to get into that trade but at this point in time i have no expirirence about any kind of stuff. right now i have an old snowblower engine that i wanna make a cart out of. can someone write a rundown of what i need to do and how too do it? much appreciated
Greetings from Canada Eh
8BallBass
Raywelder
Not an Adm¡nistrator
Well, If the engine is a horizontal shaft, Then you have a good start.
Then you will need to figure out what kind of clutch you want to use.
Get a Frame, Or build a frame, if you have the tools.
Wheels, Axle, Sprocket, Chain.
Set up your front steering and everything.
You could probably find a good frame on craigslist for well under 100.
Then it would just be down to find a clutch and mounting the engine.
8BallBass
Well when im setting it all up what would i wanna drivethe wheels with because a snowblower has the 2 drivers right one for the auger one for the wheels..what would i want too use for more power/speed?
Raywelder
Well, I wouldn't know about that, You need some pics of the transmission.
I would separate the engine from the snow blower completely, and put a clutch on the crankshaft. Unless the snow blower gearbox will work well for some reason.
