Abtheman28
Hey guys, I now have a highly modified gx200 clone motor which has all race internals. I am also running a milled gx160 head for higher compression. The problem I am having is leaking head gaskets after a period of driving the kart hard. I started off using a genuine honda gasket which lasted quite a while and then changed to a 0.10 metal type gasket (single layer) which was a lot of fun using this with the higher compression but lasted one day of racing then it coughed and splattered and broke down on the side of the road. I pulled the head to find the gasket had not blown but had leaked and was obvious by the exhaust mark on gasket leading towards outer edge. I found a VHT head gasket cement which apparently can be used on all high performing motors and all different types of gaskets from metal to cork and was tested on huge HP motors in USA. Would this product be my best bet? I have also just ordered copper head gaskets from NR racing in the USA in the hope I don't have this problem again. Any info would be appreciated
