Abtheman28
Hi all. I recently brought myself a brand new gx200 clone go kart. I did my research after being new to go karts and found out if I replace the valve springs with 18lb springs and use a billet rod and billet flywheel after removing the governor (which I've done all of the above) plus using a free flowing exhaust J pipe and .615 bored standard carb with a 140 emulsion tube and 0.37 main jet. The problem I have now is when I pull start the engine it savagely rips the cord out of my hand! Not all the time but maybe like the 3rd or 4th pull. I'm guessing cause of additional compression with the slightly longer rod would cause this problem? I have just installed a mild race cam and I have a milled gx160 head with stainless valves and chrome Molly pushrods, guide plate and billet rockers plus 26lb valves coming with increased lift. But now my guess is these additional add on performance parts will only pull the cord out of my hand even harder? If this is the case I'm guessing everyone who has a performance kart motor must use an electric start? Is it easy enough to install a starter motor on a gx200 clone motor? Any info would be appreciated as I like having 10 fingers!
