Go Kart Dyno - FOUND ON CRAIGSLIST
7thofa2nd
Barberton, OH
Go Kart Dyno - $1000 (New Franklin) OHIO
Vintage go kart dyno. Built by two mechanical engineers. Uses a hydraulic pump to load the engine at variable rates. Also used to break in fresh rebuilds before going to the track. Has a manual fan to keep engine cool while testing. It has a Hortsman axle clutch to allow the engine to run free at low rpm. Tach and temp gauge and a lb scale to measure torque. This thing is heavy! I will deliver in a 25 mile radius of Akron. The Yamaha engine in the pictures is not included, it was set in place to display the design. I can not display it in use, but I will assist buyer with set up. Please email through craigslist if you would like to see it $1000 or reasonable offer.
Don't I wish I had the space for it... :censored:
