Hi everyone…….
I have a RZR170 clone that I’m repowering with a Honda GX390 and need a bit of help with the gearing ratio.
I’ve seen calculators for this, but I’m not sure if they take into account the CVT ratio and gearbox ratio.
This is my planned setup:
Comet 44 magnum 1” bore driver
Comet 44 8.5” driven 3/4” bore
Honda GX390 1” output
Backing plate with a 3/4” jackshaft built in
Blast LED 40 series reverse gearbox
The buggy is a fairly heavy (600#+)mini side by side with aggressive 25” tires.
It will be used almost exclusively off road.
So I’m kinda wondering where I should start with the gearing to avoid burning up belts and clutches???
I’m not too concerned about top speed as I’d rather have reliability over speed.
I have a 520 series 42 tooth sprocket on the axle already and there isn’t much room for a larger sprocket without sacrificing ground clearance.
Any ideas where to start with the sprockets????
Thanks in advance!!!!
