Last year I swapped out the 150cc on my minibuggy with a 420 predator. I just ended up replacing the entire rear swing arm. The old swing arm didnt really have suspension because of the way it was designed. It was really just for show, the swing arm had a rubber stop at the top of the motor mount. You can see the new one here:http://www.diygokarts.com/vb/showthread.php?t=28874
Anyway, Obviously by doing this I lost the F/N/R. So I have been looking around for a new gear box. I had purchased a comet gearbox but didnt like it at all. Never even attempted to use it. I ended up selling it to kartfab. (hope he got good use from it).
A few months ago I purchased a new gearbox from ebay. I really like it. But it was made for a 30 series and the input shaft wasnt long enough for any pillow blocks. It was also a 5/8" input shaft with a key that was made for a TC that didnt have a built in key.
I had the input shaft remade to a 3/4" with a keyway made to fit my 40 series TC and long enough for pillow block support (as seen in the pic)
Overall, I really like this gearbox! I like the way the shifter knob controls it. It also has a "pressure hole" in it like the bigger more expensive gearboxes. I couldnt find much info on it online, but taking it apart to have the input shaft remade it seems the gear ratio is 1.3:1. I think it is from the trailmaster go karts.
So far I really like it! Havent put it to the test yet but I'll keep you updated. So if you're ever in the market for a F/N/R gearbox, I give this one a thumbs up for sure and they are not too expensive.
