Does anyone know of a gas gauge gas cap that will drop into a predator 420 stock gas tank?
D dtippery08 New member Messages 4 Reaction score 1 Nov 30, 2022 #1 Does anyone know of a gas gauge gas cap that will drop into a predator 420 stock gas tank?
madprofessor "Loose Cannon Creations" Messages 2,899 Reaction score 888 Location Jacksonville, Florida Nov 30, 2022 #2 Splice a barb tee into the flexible fuel line from the tank (1/4" I.D. is common), running the fuel through the main line (straight-through) of the tee. Use the branch to run a short piece of clear vinyl tubing up vertically to somewhere well above the highest part of the tank, and put a small breather filter on the end of it. The line should of course be strapped on vertically with zipties or better. The fuel level will always be visible in the clear tubing, and the open end with the filter on it will keep the ambient air pressure on the tube, instead of compressing it, which would lower the visible level. As a bonus, it makes an excellent breather for the tank to flow freely. Links to possible examples of parts follows.................. Amazon.com: Breather Kit for Billet Air Filters Predator 212 Clone GX200 Engines Mini Bike Go Kart Kit 2Pack : Automotive Amazon.com: Motion Pro Clear Motorcycle PVC Fuel Gas Line - 1/4" (6mm) - 10' Feet : Automotive Amazon.com: Joywayus 1/4" ID Hose Barb Tee T Shaped 3 Way Union Fitting Intersection/Split Brass Water/Fuel/Air : Industrial & Scientific
D Denny Canned Monster Messages 8,479 Reaction score 4,713 Location Mayberry, Indiana Dec 3, 2022 #4 There is none, I’ve looked.
