Hey everyone,
I am not sure who has tried to do a front brake addition to a manco intruder, or any go kart with 5/8 inch front axle for that matter.
But I am trying to find a wheel hub that has front disc brake mounts, as i bought the 3 brake system off of GPS with the intention of swapping out the rear hex axle for a 1 inch round with disc brake in rear and disc brakes up front.
I also bought a chinese front wheel hub with the standard 6 hole disc brake mount, and the holes line up for mounting the rotor, but i did not notice the fact that they were for a 17mm axle... (And the stock axle on Manco is too long anyways).
So my question is, has anyone found a front wheel hub with rotor mounts for disc brakes that fits 5/8 inch axles?
The closest thing i have found is this Trailmaster Wheel Hub but the bearing looks to be 15mm ID x 35mm OD. Since 15mm is slightly smaller than 5/8 i am assuming they will not fit.
I don't have a bearing puller, or else i would pull it on the chinese 17mm wheel hub to see if the outer diameter is 1 3/8 inch (basically 35mm) and maybe just order some 5/8 bearings, so if all else fails, that is my plan, followed by getting the trailmaster ones above and swapping out the bearings since they are in fact 35mm OD.
What do you guys think?
