karte_m0lim
Birds Aren't Real
yes, I know that I am not finish my current project but thinking forward
so , I have small 50ccm motor with automatic gearbox like one on the pict:
this should be for my 5 yr old son .
so for first thing , i planning weld monocoque, separate nose cone and engine support:
bolid 1
I start drawing in auto cad (noob).
also would like to make wishbones , pull rod suspension for front end with torsion bars .
at back, I think it's too complicated to make independent suspension for each wheel cose then have to have two axles which must be able to move up-down and inside -out so thinkig of solid live axle and one central torsion bar and spring (similar like anti roll bar)
on drawings you can see what is the idea.
also would try to put brake disc and sprocket inside bodywork.
would appreciate for your thoughts ..
bolid 1
