Bldc 48 volt motor and matching controler ...6-1 sprockets...everything has worked well for 10-12 rides.....when rear wheels are off the ground everything spins nicely.
when a rider sits on it and attempts to drive.... you hear a sound which sound like the chain skipping over the sprocket....when you look back at it, its not skipping, the motor appears to be chattering, and it will make forward motion at about 1/2 mph. One shop suggested that the "Hall" wires from the motor are not solidly connected to the controller fitting. I bought a "motenergy" tester, and it tells me the motor is fine ( all hall effect sensors are firing correctly ). I've replugged the connecters back together....and again if the wheels are off the ground I get full RPM spinning....but with a load the motor just chatters......Help me brothers
Da Flash
Da Flash
