well upright is a relative term I guess
it implies "right side up" no?
and if your car is upright.. it has all four wheels on the ground.. sooooo
why not google for vertical kart stand instead that yields some more results, some of which appear to be easily replicable...
I mean there's a short one (two forks grab the seat crossrail, the rest is gravity fed essentially)
just five relatively short pieces of square tube, two forks and four wheels..
belly to belly is going to be rather difficult though..
keep in mind that you cannot as easily place the kart on such stand if you cannot tilt it forward ( where the other kart is)
And you cannot remove the "front" part of the legs otherwise that thing will tip over once you do tilt the kart (trying to get it on or off)
but you can still put two karts belly to belly with two such stands IMHO
