CycleKart Progress
Kelly Wood
The Mad Kartist
Salt Lake City Utard
Seeing I started here with my original rides, things progressed into Cycle karts.
Although not done yet, may I present my latest project, coming together quite nicely.
We call her Sargette'
Thanks for lookin.
TT540
Newb
Huntsville, AL
Utard. that's funny.
Kart looks cool! I have never seen a front setup like that. Can you adjust camber? Or is it more of a leaf spring pre load adjustment. hard to tell with the angle with the wheels on.
still love it :D
Know what it reminds me off? "Iron Sky" it has that 'alien' WWII steampunk vibe...
just as if you were in charge for making their props :D
Kelly Wood
The Mad Kartist
Here's what I did when I "threw" it together.
It's made up of a trashed golf kart front end & other pieces.
Kelly Wood
The Mad Kartist
Man I really like it!
Hey Brent!
Let's get together again... perhaps you should join us & build one. IT's right up your alley and PERFECT for... well... us... as we turn older.
Oh yes... a little "fond memories" pic for ya.
hehe!
Kelly
---------- Post added at 08:05 AM ---------- Previous post was at 07:55 AM ----------
still love it :D
:) Thanks old friend.
Kelly Wood
The Mad Kartist
Brilliant!
Thanks!
Yep, these cyclekarts are quite fun. There's some pretty simple rules to the whole thing but that just makes em the fun, light-hearted things that they are.
Lots of people do this and there are groups all over the place.
If anyone's interested, the basics of what is a "Spec" cyclekart. (the reason for Spec is so when you attend an event, the race is equal.
Ultimately, you can do whatever you want... but if you want to race, you gotta follow the rules.
The basics: (taken from the cyclekart main site)
<<<BEGIN>>>
Cyclekarts are compact, lightweight, sports machines, home and hand made by their drivers for the pursuit of classic motoring sporting excitement. They're not built to be serious race machines or show cars. They're built purely for the personal satisfaction and fun and of driving a machine you've built yourself. As driving machine, the CycleKart formula loosely limits certain aspects of the machines to maintain good sporting performance without jeopardising the light-hearted nature of these machines and the people who build them.
CycleKarts and their builders don't like to take things too seriously, but do encourage good, sporting competitions for fun. The Cyclekart specifications allow for all the cars built being similar in performance, without strictly governing the rules.
Cyclekarts are generally not for sale, as they should be an expression of the owner's individual styling interests as well as sharing the pride in building one's own unique kart. Cyclekarts are built for the pleasure of the imagination, the design and the building of the kart. Cyclekats are based on the styling of 1920s and 1930s race cars to pre WWII. Making it look good is fundamental, performance is secondary in the Cyclekarting community.
Stevenson CycleKart Specification
A one-seat car using Honda 17" x 1-3/4" or 2" rims, 2.50" x 17" tires (2.75" have been used on the Alfa), a 38" track, wheelbase as close to 66" as the aesthetics of the car will allow (err on the shorter side for more abstract cuteness and general attractiveness), weight no more than 250 lbs, and powered by a 200cc, single cylinder, 6.5 hp Honda OHV engine (the GX200). A CycleKart should not cost more than $1,750 to build in 2001 dollars. This is to avoid "spending races" where people start hiring out parts and making things too nice; we're not making show cars, and an element of scrounging adds to the fun.
Measurements and Notes:
* Styling - 1920s and 1930s race cars, maximum pre WWII. Make it look good. Performance is secondary
* Overall Maximum Length - 98" (2490mm)
* Overall Maximum Width - 40" (1020mm)
* Wheel Base - 66" (1675mm)
* Track - 38" (965mm)
* Chassis Frame Rails – (2) 1" x 3" (25mm x 75mm) steel (1/16" thickness is sufficient)
* Body Work – 1/4" (6mm) plywood and 3/4" (18mm) plywood monocoque box, or metal work
* Body Width - 14" (355mm) wide at front axle, 20" (510mm) wide at seat back
* Front Axle – 1-5/8" (41.5mm) O.D. tubing, dropped to accommodate the leaf springs
* Rear Axle - 1" x 36" (25mm x 915mm) long axle
* Front springs - 24" x 1-1/4" (610mm x 38mm), 2 leaf, 1/2 elliptic
* Wheels and tyres – Honda 17" x 1-3/4" (177mm x 44.5mm)
* Minimum Weight – N/A
* Maximum Weight - 250 lbs (113.6 kg)
* Engine - 200cc, single cylinder 6.5 hp Honda OHV engine (GX200)
* Engine Location – Rear
* Drive - Comet TAV-30 (or similar) unit to one wheel only
* Drive Chain - #40 chain, 72 tooth main sprocket (#35 chain & such works too)
* Braking – Single rear wheel by mechanical disc. No front brakes allowed
* Variation – Adjust all or any specifications above as required or desired
There is no lower weight limit, as we feel that this is a perfect place to "cheat". Lighter cars will perform better, will also have better braking (using the same brakes) and the structure will be loaded less heavily: All good things. There's a natural lower weight imposed by the strength of materials used, but it would be fun to see what could be done. Lighter machines are more prone to breaking, so please make safety your priority, and keep in mind that you'll spend more time fixing things than others might. It's all part of the fun of CycleKart design.
<<<END>>>
https://www.cyclekartclub.com/
In all of that, they do really like it (and prefer it) if you have an "Inspiration car" you used to base your design off of.
Mine, was based loosely... on the GN Jap. (very loosely that is, with a little pre / wwII military styling thrown in... imagine that.)
Kelly Wood
The Mad Kartist
Little update for anyone interested.
Lotta work been done... Cyclekart Sargette' nearing the finish line.
Now finishing up the rear clip.
Yep
Kelly Wood
The Mad Kartist
This is just awesome. Love the shape of those side pieces.
Thanks! They'll be on tonight, along with the rest of the rear end.... Next up, the brake system... seat back... a few other things... then... it's drive time.
Yep.
---------- Post added at 11:46 AM ---------- Previous post was at 11:41 AM ----------
Cool Stuff!!!
With Inflation, what is $1750 in 2001 Dollars in 2018?
http://www.calculator.net/inflation...ear1=2001&coutyear1=2018&calctype=1&x=94&y=12
$2492
Thanks! I'm under 1000 bucks for this beast so far.
Kelly Wood
The Mad Kartist
Oh yes... an artistic shot of her, on an actual military surplus metal table... in the Utah Cyclekart headquarters.
Desertduler
If I build one Kelly then I am going to have to break the engine rule.
Looks real cool please post a video of it when you get it done.
Kelly Wood
The Mad Kartist
LOL! Cool. Gopro ready to roll here.
Ultimately, you can do whatever you want.:thumbsup: But... if you want to compete in the races (like our planned butterfield canyon rally... Tooelle to Herriman) and get the trophy... it must have that engine.
These things aren't really heavy, putting too much power on one can get sketchy with just one wheel driving it / braking it... but you know that stuff. I've seen the stuff you can build my friend. :)
Come drive with us!
Oh yes... the current weight of this monster, is just 194 lbs currently.
Desertduler
Come drive with us!
Well now that sheds a whole different light on things. I know the road from Butterfield Canyon over to Middle Canyon on the Tooele side very well. That would be a blast! Then I indeed would stick to the rules.
