karl
I planned on doing a big bore single , but I found a much better donor.
The bottom end is a CH640 Kohler Command
38ci (624cc)
3.03 bore x 2.64 stroke
8.5 :1 compression ratio
Rated 20hp @ 3600 rpm , 32.6 ft/lbs @ 2600
Pressure lube (very handy for a turbo), electric start and charge.
It is in very nice condition, crank, rods, bore all looks good. Unknown hours. It is worthy of a set of billet rods.
Lots of parts available for pulling tractors.
https://mwsc.co/collections/kohler-command-engine-parts
Should have no issues spooling a rhb31
I only have the bottom end, so I will be using 24hp Courage heads
Because they were free, And I think the valves and combustion chamber are slightly bigger. Custom pushrods are in order.
Anyway It will be a slow build, as parts are not cheap. And I want to make it legit as possible.
38ci (624cc)
