coleman ct200u-a build
jmaack
And the waiting game begins.
jmaack
Started on intake going to smooth out tomorrow. Need some good stones now.
karl
North east Ohio
Nice! What Cam are you gonna run? Need to pick me up another as my fresh cub cadet/ MTD 208 block
uses the same cam as non-hemi's.
jmaack
mod 2 for now.
Little bit more to get out tomorrow. Parts come then, should get most done this weekend.
jmaack
Well a delay for some reason. My parts were to be delivered Friday, then delayed to today, now to tomorrow. They were 20 mins away, now they are in another state 4 hours away. Smh. I have lost complete confidence in fedex, ups, and usps.
jmaack
Getting ready to plumb pulse pump tapped and nickel painted . Still waiting.
Before and after third and fourth pic.
jmaack
Wow..great prep, looks good
Thanks. I sanded degreased sprayed 4 light coats. Came out clean. Here is finished product. Also picked up some valvoline high zinc oil.
karl
North east Ohio
been seeing that also. Found this online only one I could locate. They had to type in numbers but it worked.
Thanks bud, thought about it today, looked back and that coupon expired today.
Drove up and they had only one hemi left, dozen + non-hemi's. That coupon saved me $40.
Just in time . Probally the end of the $99 special.
jmaack
Lots of pics. I'll go back through and straighten up though. If you've seen one you've seen em all. assembly valve lapping flywheelblapping etc.
jmaack
more pics. Have to adjust valves, and a little more. But it's basically there.
jmaack
She lives. got a little ticking from valves I think. set at .003 edit. not ticking air pulsing from open nipple.
jmaack
Got a little kickback issue. Valves set at .003, figure it might be advanced flywheel. It isn't as bad as it was maybe the second adjustment will work. exhaust is slightly tighter than intake but still can slide the feeler gage through.
jmaack
headache after headache. This pipe is not the one I wanted but was the one i was sent. Starting to lose patience. Anyone from gopower sports on this site? I just don't see how this pipe can work with this bike. Muffler pressed all the way down on tube. pipe is a few inch from rack without muffler. Engine is all the way forward.
jmaack
Here is the exhaust. No other way to make it fit. GPS said buy a heat shield that it was the right pipe. This is how much I had to cut off to make it where it fit. I don't know if I'm going to use it or make my own. I am not happy though.
