coleman ct200u-a build
jmaack
Went for a ride this morning, I still can't get the bog out. Plus my chinese mikuni drips gas after sitting it will drain the line and some of bowl.. I will be buying a real mikuni.
jmaack
Here it is with a half a tank of gas. Yes drain is closed. it won't quit leaking. I'm livid after making a small puddle on the driveway.
jmaack
Well change of plans. The flathead is going on the back burner. I will be going with a stage 2 hemi predator.
jmaack
No better feeling than tearing in to a fresh predator.
jmaack
good bye governor and oil sensor. No turning back.
jmaack
Stage 2 on its way. Got a little something for OMB warehouse also.
jmaack
Will finish the final tear down and clean this weekend. Should start then or early next week on build.
jmaack
I am struggling finding the same header pipe I used last time. GPS has one now that has an ugly kink in it and it isn't the one i want. Can anyone find it for me on their site before I pull my hair out?!
jmaack
Just gonna sennnddd it!
Lookin good, buy em while ya can, price of china motors are going up.
been seeing that also. Found this online only one I could locate. They had to type in numbers but it worked.
  • 84_ITEM_PREDATOR_6.5_HP__212_CC__OHV_HORIZONTAL_SHAFT_GAS_ENGINES_1616192902.8383.jpg
jmaack
Governor arm, and Governor gear holes tapped and sealed. 1/4 fine thread. going to dremel and slot with loktite but either way can't fall in. Have to figure out something for oil sensor hole. Might use a npt plug idk yet.
jmaack
little more progress
