Ahaa there's your 'problem' *giggle*
while the MaxTorque SS doesn't mind at all to run inboard,
some copies obviously do!
inferior material for the baseplate is all it takes..
and inboard the shoes are trying to bend the tabs back straight with every jerk,
and the tiniest bit of movement of the tab can work harden the baseplate enoug to cause such failure over time (well obviously
Frankly, I haven't seen such failure yet,
but seeing it I'm not exactly surprised to hear it's a chinese clone clutch.
I would be to see such on a Maxtorque or Hilliard
(I wonder why one wants such if the original Maxtroque SS is not more expensive really
just more rugged
Anyways.. thanks for sharing.
great to see a clutch failing that's not blued over entirely due to bad gearing
or rusted all the way through due to bad maintenance every now and again
PS really? you bolted a predator in?
I don't judge..
but personally I liked the 'old school' theme you got going on there...
and an OHV ruins that a bit IMHO.
PPS IIRC maxtorque sells spare base plates.. I wonder if it'd fit
