Sure is, my west bend is set up so changing the flywheel/ recoil determines what direction it runs.
2 cycles do not have valves or camshafts, and the ports do not know or care what direction the crank is turning.
All the ports see is a piston moving up and down.
Lets do it!
Oh.
Anyway back on topic, I would start by turning the motor over to top dead, and looking at the flywheel magnet
in relation to the coil. Then lap the flywheel to the crank so no key is needed, then put it back on the crank
so the offset of the magnet to the coil is on the opposite side. Make sense? That should get you close enough , a couple degrees of timing is
not going to make or break it.
Now all that's left is the recoil, little bit more difficult. You could just remove it and use a manual
recoil cup, wind the rope around it for every pull.
