dwcopple
backyard hooligan
I'm building a Predator powered dirt bike and need a good inexpensive place to order some #40 chain and a matching rear sprocket 44-48 tooth. Any vendors that give forum members a discount? Where is your go-to place?
It's a parts bike I'm stuffing a Predator into. Never had an engine in my hands. Guys that built these on YouTube are running 10T driven and 45T rear off the TAV2. Not sure why guy above is saying 75-100 is necessary.Wow. I guess you really do need to replace that rear sprocket. I could surf on the curves in those folded over teeth. Was the chain skipping teeth under load when you rode it last?
MathNot sure why guy above is saying 75-100 is necessary.
Simple, The torque converter adds 10% overdrive in top gear. Add that to the RPM in the calculator.I don't see how that calculator works when you have a CVT trans though. Please explain.
Then do it! It's on the internet, must be true!Well @3500rpm with 20" rear tire and 10/60 I only get like 36mph. The guys on YT are getting near 50mph+
