Cheap, Reliable 6.5 HP engine
risto
...watches you sleep.
Central Florida
I recently bought a 6.5 horizontal shaft engine from harborfreight.com. It was $160 including shipping. The link is here. I put it on my small, 80-pound-frame go kart and it gets me going about 30mph. 60T axle sprocket to a 12T clutch sprocket, #35 chain.
I posted this for two reasons:
-I wanted so share a steal for a brand new, Honda-clone engine.
-I wanted to know what modifications should/could be made to improve my speed, engine life, etc.
any help is appreciated.
thanks
EDIT:
and for those of you NOT living in California: Save some $$
my_mini_bike
a new performance air filter, different carb, a different exhaust [ i complely took the exhaust of my kart and there was way more power but i was far too noisy], racing spark plugs etc etc... or a torque converter like Jblankster suggested
Jblankster
Illinois
if its too noisey. get a high flow racing muffleler. or go with a straight exhaust(just a pipe attached where the muffeler was)
5hpbriggs
Matthews, North Carolina
Okay here we go:
Better flowing carb here talk to this guy I belong to the same forum he does he drag races mini bike and he runs honda motors. www.icehousehighperformance.com
Cams: If you want they run from $100 all the way to $260
www.nr-racing.com
Rockers: Rollers $180 a set
OR>>> www.icehousehighperformance.com 1.2 ratio rockers
springs: if you run a high lift cam yes it is a must
Porting: yes it must flow better
valves: If you want-
Exhaust pipe- If you want a high performance motor use a robertson pipe. Remember it must (motor) flow!
5hp
risto
Central Florida
I was working on getting a new muffler today...
is this one of those "make it yourself" kind of things? because all the honda-style mufflers i have found around here are more or less replacement parts.
I had a new air filter, but that someone managed to get lost in a pile of junk today...
and those were the only modifications i felt safe doing myself, as:
me + work i am not familiar with = emergency room.
thanks for the suggestions!
Jblankster
Illinois
lol yes its a make yourself tyype of exhaust thing. if its a screw in muffeler just un screw it get some pipe that will fit the threads and have it go out back.
risto
Central Florida
unfortunately it's a Honda-type muffler. So i'd need to make it fit just right. Any tips on making a muffler? or should i just post a new thread?
oh, and any other, simple ways of improving engine performance?
russo2
take out the governors..check other threeads on hwo to do so
a different spark already saud but it is a very cheap way of gettin more power
adjuste the carburator to high throttle.. but not too high
