Briggs8Stratton
Hi guys, I have here a question about identifying what size/number chain and sprocket I have. How do you figure out what size a sprocket or chain is if you don't know? I need to be certain.
Chain Number Pitch Roller* Width*
#35 3/8 .200 3/16
#40 (#425) 1/2 .312 5/16
#41 1/2 .306 1/4
#410 (#43) 1/2 .306 1/8
#415 (#42) 1/2 .306 3/16
#420 1/2 .306 1/4
#425 (#40) 1/2 .312 5/16
#428 1/2 .335 5/16
#520 5/8 .400 1/4
#525 5/8 .400 5/16
#530 (50) 5/8 .400 3/8
*Roller Diameter
*Width between inner plates
And if you also measure the roller diameter and width (inside) of the chain you can precisely identify the chain number..
Code:Chain Number Pitch Roller* Width* #35 3/8 .200 3/16 #40 (#425) 1/2 .312 5/16 #41 1/2 .306 1/4 #410 (#43) 1/2 .306 1/8 #415 (#42) 1/2 .306 3/16 #415H (#42H) 1/2 .306 3/16 #420 1/2 .306 1/4 #425 (#40) 1/2 .312 5/16 #428 1/2 .335 5/16 #428H 1/2 .335 5/16 #520 5/8 .400 1/4 #520H 5/8 .400 1/4 #520-2 5/8 .400 1/4 #525 5/8 .400 5/16 #530 (50) 5/8 .400 3/8 *Roller Diameter *Width between inner plates
I just figured it out. Thanks for the help...btw whats the difference between 41 chain and 420 chain?
i think i could add pin diameters, tensile strength and maybe plate thicknesses as well...
But i'm not sure it'd reduce confusion
But you're right.. I should have removed the h values (since they're identical except for the plate thickness and or pin diameters
done!
tensile strengthI just figured it out. Thanks for the help...btw whats the difference between 41 chain and 420 chain?
