Chain size question
Kent
Willits, California (Northern California)
I have a chain with no size marked on it. Looking at the chain measuring chart On BMI's site. It looks to be 428.
https://www.bmikarts.com/Measure-Go-Kart-Chain-Size
My measurements show......
Roller width.....1/4" / .250" / 6.3500mm
Roller diameter......5/16" / .3125" / 7.9375mm
Pitch.....1/2" / .500" / 12.7001mm
When I look at sprockets etc. I never see "for 428 chain". I see many for 41/40 and per the chart those are very close to 428. Is it alright to use parts that indicate "for 41/40" with this chain ???
actually that's not 428 chain,
that's likely 420 chain instead
Roller dia for 428 is 8.5mm inner width is 7.95mm (5/16")
and for 420 chain it's 7.77mm Rollers and 6.35mm (1/4") inner width
420 chain is fully compatible with #41 sprockets
(identical Pitch, Roller diameter and inner width)
420 is just way stronger than #41
And no, to answer your question..
true 428 chain should NOT be used with #40 or #41 sprockets.
despite all of them being half inch pitched.
luckily that's not what you have ;)
Joe-405
Enjoying New Projects
Oklahoma
So #40 chain will work for the 420 sprockets???
You can use #420 chain on a 41 or 40 sprocket but not the other way.
#40 is narrow
#41 is wider
#420 is wider than any of the above
I know cause I had to on my alsport and my last mini Dragbike. I hope I said that right. Lol
One would like to think.. but actually not the best idea..
#40 uses 7.95mm rollers and has 7.95mm inner width
sprocket width isn't ideal, and Rollerclearance will be diminished
so ther will be premature wear (noisier chain).
(it may fit though)
Same holds true for #41 sprockets btw..
but everyone's ignoring that too..
the #40/#41 sprockets you find are hopefully taking care of that,
putting the roller clearance at max for #41 and at min for #40 chain at least.
420 sprockets however will likely don't give a shirt about ANSI chain
and thus the #40 roller might be too big
(min roller seat on a 420 should be 7.85mm 0.1mm too small for a pressfit)
Sorry Joe, the other way around, #40 is the largest(widest),
#41 and 420 are actually identical in dimension,
420 uses bigger pins and thicker plates though and thus is stronger than #41 [and even than #40 at times]
