Colemanman
- Messages
- 31
- Reaction score
- 4
So i see mini bikes and go karts commonly use #420, #40, 41# 35# and the occasional #50. And id like to get a better understanding on what chain is best for a particular application.
Does any one use #40 or #41 chain on their machines? I dont see that many options for the two, but ive been using #40 on my mini bikes because i dont have to order it online.
35# seems to be the more racey choice, with more gear ratio options. I have that chain size on my azusa 10 inch rim minibike kit.
#420 is thinner than #40 but has the same height and side plates, wouldnt that make it weaker than #40? Whats the advantages of both?
$41 from what i hear is light weight version of #40 chain
What application would you use a particular chain size for?
Would you use 35# on a big block engine, or would that put to much torque on the chain?
Can you tell a difference in power loss between #40, #41, or #420,
Any reasons one would use #420 over #35 chain if the chain can sufficiently take the power?
And finally does #35 chain cause faster sprocket and chain wear do to not having chain rollers?
Sorry for all the questions, but i like to learn the whens and whys of everything and enjoy learning the more technical side of things. Thanks for reading and replying? Have a good day
