Scott.A86
Hi again folks. I have a Carter? Go kart I have been working on. (Details in my first post https://www.diygokarts.com/vb/showthread.php?t=44324)
I recently had a rear bearing blow out on the stock 3/4" live axle housed in a metal tube flared at the ends for berings. Apparently it has been bad for a while because the bearing wore down the axle about 1/4" just behind the hub.
I was just going to change the bearings but needing a new axle I may aswell upgrade to pillow blocks or a weldable kit maybe with a slightly longer axle.
I figure I can...
1. Get a new axle close to stock that fits the odd carter wheel hubs and order some bearings cause I could not find them local.
2. Use pillow blocks or hangers and get a 1" axle that steps down to 3/4 and try to use the carter hub/brakes/sproket.
3. Get a kit and completely upgrade everything. (Can't really afford right now.)
4. Hopefully yall can help me think of something in the middle. Like new parts so I can fix the kart and also use those parts when I upgrade or if you think swapping axle hangers is an upgrade.
I would like to give the kart bigger suspension with more travel and make the the cart wider to help lower center of gravity.
I figure I can...
