cam grinding
freakboy
the names 'mater
hick town
how would one go about grinding a cam.. bench grinder would that work? just dont ask what im doing just answer:idea2:
freakboy
the names 'mater
hick town
i dont really need to much accurracy for this little project here.... just need to grind off a little off the base circle..
freakboy
the names 'mater
hick town
nope oppy twin dont have a comp release..
If you grind the base circle of the cam down and get longer push rods its pretty much like getting a higher lift then stock cam.
mike75925
thinker and tinkerer
Alto, tx
you could do the bulk with a bench grinder. you will probably want to use a file to straighten everything back out. there was a guy on 4cycle that welded his up with good results. since you are doing what you are planning, why not flatten out the tip a little for duration? fortuna per ut? good for you?
freakboy
the names 'mater
hick town
no i not gona flatten the top cause that wont do nothing for duration it will only take away lift.while if you do the base circle it gives more lift also there are some more secrets to this i wont reveil...
mike75925
Alto, tx
the flatter the top (not flatter, wider arc), the more duration. from what i've read you would rather have duration than lift. unless one of your secrets is a slight duration increase. remember to watch your ramps. you could end up making comp releases. you are going to need bigger pushrods though aren't ya?
freakboy
the names 'mater
hick town
yup im gettin that taken care of soon anyway... this oppy is gona be torn down for the second time and i got way more tricks up my sleeve hehehe...i got a list about a page long of what im going to do to this thing... this opposed wants to go....anyone got any secrets for getting more tourqe?
freakboy
the names 'mater
hick town
CNC surface grinder w/ a CNC rotary table
lol unless i can find one for 10 bucks im sol on that..
and mike higher gearing wont do anything for me cause im tryin to get more tourqe outa this thing so i can gear the dog hell outa it to beat the ohv singles
and i had the adjustable jet out a little to much on the low end and the thing would just load up with fuel bog out and dump unburnt fuel.
mike75925
Alto, tx
isn't higher gearing 6:1, 7:1, 8:1? 6:1 gives me plenty of torque. what is this engines rated torque anyway?
oscaryu1
Knife edge crankshaft, shot peen connecting rod, lighten flywheel, port and polish, replace bearings with sealed bearings to get rid of the seals....
Your turn :)
mike75925
Alto, tx
won't a knife-edge create more thumping? imbalance? shot peening is for strength right? sort of like cryo treating? lightening the fly is for revability, of which a byproduct is more usable torque; port and polish is for flow. sealed bearings are for durability.
freakboy
the names 'mater
hick town
for more tourqe you want a heavyer wheel. and no way im cutting into this wheel.. its a monster of a thing and id rather not have a modded wheel on my mower. but i cant make up for it in gearing i need the toruqe outa the motor for racing so i can gear it so it goes faster cause the little single ohvs got my *** beat cause they can rev way up past 5 grand when built right but the twins got a *** load more tourqe then them. and if i gear it for tourqe ill be goin slower then a frozen dog turd going up hill.
theres no way of replacing the bearings on a oppy twin. port and polish is on my list
mike75925
Alto, tx
ok in that case, you might be able to run a 16tooth clutch and a 60rear sprocket. are you gonna stay running the stock carb? do you already have an aftermarket filter? since it is a twin, you could run twin carbs. what's your bolt pattern for the intakes? how many cc's per cyl? two of these might make her run like a scalded dog:
http://www.partsforscooters.com/114-4?sc=2&category=13
freakboy
the names 'mater
hick town
lol gotta be stock apearance on the outside xcept for billet flywheel velocity stack and air cleaner. lol clutch whats a clutch ahaha.. lol im goin 5 inch pully to 5 inch pully then the rear sprockets i havent decided yet into my peerless 820 and to the gorund.... the carb is moded and its a 46 CI engine... the bore is like 5 inches lol.
