Briggs twin horizontal conversion
karl
North east Ohio
I have always wanted to do this , and I think my kart would be fun with 20hp and a 40 series tc.
This is like a very poor tutorial , so hold my beer and enjoy!
karl
North east Ohio
Stuck a bolt where the gov arm was.
Made up intake and side cover gaskets.
Undecided on what carb to run
Will run duel exhaust with 2 can mufflers
Found out oil dippers are part # 691733
Time to make the sump
anickode
S.E. Michigan
Yeah it's not as simple as sealing the leaks and making a bracket so it stands on it's arse.
If it was, there wouldn't be 746254960263758 threads on "is it possible to put a lawnmower engine on a go kart?"
Those vertical shaft opposed twins were plagued with oiling problems as they were. Turn it sideways and run it with no governor, and I don't see this going very well. It might work out for you though. This design was always much better in a horizontal configuration. If you can get the sump and dippers right, this could be a good strong engine. Gotta love a 180° v-twin
It would be cool to run a couple ~12hp downdraft carbs mounted on short runners straight above the intake ports.
karl
North east Ohio
So your making your own oil sump and splasher ?
Making my own sump. I bought 2 of these
Factory replacement for the horizontal version of the engine.
Today 05:51 AM
Not quite as simple, but as long as the oil level is right in the motor I think it will be ok.
I want duel carbs, I still might but its much easier to make 1 small manifold, then there is tuning, chokes, throttles, ect.
B.M.800
TheBeal.
Central PA
Its about time someone is doing this. :D
I have 7 vertical shaft oppys I been wanting to do this.... but I have enough projects as it is.
offroading73
been thinking on my v-twin and wonder if on something like this. will the mounting holes hold up to being mounted side ways with the torque. i did find an outlet next to my oil filter for a pressure gauge.
there is a guy on youtube that did a v-twin and used a exhaust pipe elbow to mount his carburetor.
https://www.youtube.com/watch?v=Xb_zYsLjCkU
good luck!
karl
North east Ohio
good luck!
Well , on my twin, the oil sump will have the mounting holes to bolt down the motor. Just like the factory did. I would buy a factory one, but finding it is quite the challenge.
I am probably going with a large tillotson or mikuni I have sitting around.
Welded the exhaust up, pointing back for kart use.
karl
North east Ohio
Found a mikuni vm32 that should work good.
Needs rebuilt and cleaned up.
anickode
S.E. Michigan
I kind of like that long runner intake. I wonder if one of those would bolt up to my 18hp horizontal opposed twin...
karl
North east Ohio
I gave up on making my own base , As I found one nos on ebay for cheap. The part is #393559. It says for 16hp but fits mine.
Electric start and charging will be nice
karl
North east Ohio
If anyone was wondering how to add/ check the oil
The pan had a 1/4 npt hole with a plug in it.
I got two 3/8 compression fittings. Cut the dipstick short, clamped it down.
I will add a support bracket from the side cover to hold up the dipstick.
karl
North east Ohio
Got the dippers in, torque spec is 190 in/lbs
Put pan on with new gasket, X4 3/8 cap screws 3.5in long were used.
19 ft/lbs.
Has oil in it now!
Made the carb adapter, need a rubber boot to start it!
Hopefully this helps someone doing this conversion, as it was hard to find the parts. No one says buy these two part numbers, or done any kind of helpful tutorial.
karl
North east Ohio
Well it runs !
