gegcorp2012
Hey, If you have a band saw, you will eventually have a broken or damaged blade as well. I took my first damaged blade and sliced it into a few pieces to make a couple of other blades....
I used a grinder and drill to make the right shape to try a piece in my "Sawzall" recip saw, however the band saw stock is a bit thinner.
Worse case would be the manual option - to recycle the band saw blade stock as a hack saw blade.
