Axles for IRS
Pinhead
Kansas
I recently picked up a go kart that has been repainted and am having trouble identifying. It's got a simple Independent Rear Suspension consisting of a shock, trailing arm, and axle with a single inboard U-joint.
Unfortunately the U-joint on the right axle was replaced by the previous owner who couldn't find the correct size so they honed out the axle to fit a bigger joint. This eliminated the ability to use retaining rings (snap rings) to hold the entire assembly together.
It worked for about a week after I bought until I lost a cap. Now I need to either "fix" the u-joint or replace the axle(s).
Does anyone have any idea what brand/model this go-kart is and where I can find parts? I haven't been able to find any images online of anything similar.
EDIT: Now that I'm a full-fledged member of this forum, I was able to find an almost identical thread by lyfesaver.
It's a Baja Blaster 65.
Many thanks.
Pinhead
Kansas
Now that I've found the make/model, I'm having a hard time finding axles. According to alpha-sports.com, the axles are discontinued/unavailable.
Looks like I might have to build a new IRS with cv axles...
I have one that I bought brand new back in 2008. The company that imported them Baja Motor Spots went out of business quite a few years ago. I have looked far and wide for parts with not much luck. Finally found a place in
Texas that bought some of their old stock. No idea if they have what you need.
The lace is called Scooter Outlet. Phone number (915) 820-2565. They are located in El Paso. I have made a couple of purchases from him. Seems like a small operation, kinda slow to ship, but the stuff showed up and it was what I had ordered. Hope this helps. Good luck.
ONE-EYE
Knoxville, Tennessee
Worst case scenario is you could install a carriage and weld up a new plate. Then you could run a straight axle and still mount the lower part of the shocks to the carriage. Might be a lot of work but just brainstorming here lol
Pinhead
Kansas
This kart will spend 99.9% of its time off-road so I don't want to go with a solid axle.
Tempted to pull the IRS out of my '80 Subaru wagon and graft it in. So many projects, so little time...
Pinhead
Kansas
Thanks for the tip. I contacted them and they no longer have the axles in stock.
Pinhead
Kansas
Clearly you understand the mechanics of the IRS applications. What I went looking for on YouTube was a video of (I think) Cars and Cameras doing a "semi-independent" rear suspension, that's what they called it anyway.
If yours is what that sounds like to me, you'd appreciate the video. There was a single U-joint in the center of the kart frame's rear end, and that looks basically like a trailer setup being towed on a trailer-hitch ball. Difference is that the trailer was pushing the kart, not vice versa. They had a single cross brace like I think that is on yours, and it worked fine. Still can't get past the feeling that it's a really hinky way of doing it.
Pinhead
Kansas
Yep, I've seen that one. Red Beard's Garage. :)
Thanks for that pointer, went back and looked at the RBG video. Write this down: "I was wrong." You won't see me say it often. At least I did qualify my thought that it was a C and C video with an (I think.)
What was totally wrong was me saying it had a U-joint attachment. It was a big heim joint, as were both ends of what he calls a panhard bar, the part that keeps it from swiveling. Still uncomfortable with the mechanics of it.
Pinhead
Kansas
What is your reservation about the design? The weak point in the middle or the frame or the strength/stability of the panhard bar?
Guess I just prefer a zero application of stress from the "swingarm" trying to rotate, which it does do. Either rear wheel can independently rise up, and it rotates the swingarm and motor with it. The panhard bar only prevents the swingarm from swinging left/right.
I know I'm an OCD overbuilding nutcase, but I just really like a heavy duty swingarm that only has an up/down way it can move.
Note the swingarm pivots in pic below, uses (6) 3/4" cast iron pillow block bearings, (4) on the frame, (2) on the swingarm.................100_0172.JPG
Pinhead
Kansas
I believe that is the entire point of the design, isn't it? To give each wheel a "semi" independent movement arc...?
FlyFrog
Kankakee Illinois
Note the swingarm pivots in pic below, uses (6) 3/4" cast iron pillow block bearings, (4) on the frame, (2) on the swingarm.................View attachment 130114
them are some tiny wheels
Those little 12" tall tires on 6" split rims were temporary during the (SchizoBallz) build, and are going on the next (BareBallz) kart build. Have my 16" tall x 4" wide on 8" rims on it now, 8" wide tires will go on at the end. Want taller tires for the 8" rims, but not unless I can work out the gear ratio/motor rpm dilemma. Upcoming test run will be on the new 9:1 gear ratio, have to get the rpm's up to at least 4500.
Pinhead
Kansas
I was able to find a new u-joint from a local farm parts store and after some grinding, got it to fit. (y)
Another issue I had is the rear wheels were shifted rearward, causing the rear to be toed-out. You want to talk about unstable at high speed... A couple of new mounting holes later, I got the rear aligned.
Top speed was measured at 36 mph though I think my throttle cable had loosened which didn't give me WOT. I'll have to do another speed test.
The front has terrible bump steer because the welded-up steering knuckle put the tie-rod at a ridiculous angle relative to the A-arms. I believe that's my next project.
