ThunderKart79
I toke the front fork off of my sons CT200U so I could weld 2 reinforcement plates on the front of the frame and neck I did not pay any attention to bolt orientation when I disassembled the front end Things to keep in mind 1# this boy is cautious at first but confidents grows 2x the pace as his since does 2# 6.5 hp to the very least 15 hp honestly after double checking my math on paper we are running 12.9:1 compression with enough lift and duration to show any predictor that we come across why Tillotson designed their Hemi head as an improvement over predictor well I did put a .570 compression height pred flat top but after spending $40 on a kit to cut valve reliefs wish I would have put a wiesco in it in the first place 3# I also need recommendations on installing disc brakes all around I just need to know what rims to replace my PPP 8” rims with also just a random question about mini bikes is I am curious as to why you hardly every see foot brake setups on minis dirt bikes and 4X4’s always have the rear brake operated by foot
