r_chez_08
Should be in the shop...
Your greyhound is a Honda gx200 clone.
If you cannot fix your recoil check something put on it- there are two styles.
Does the recoil have metal or plastic pawls? (pawls are the little arms which engage with the engine when you pull the recoil.
Also, can you take a picture of the metal starter cup which the recoil turns over (metal cup sticking out where the recoil was.)
Pretty sure the recoil in the link has metal pawls, and most Honda clones have metal pawls, but it is best to double check!
Btw, you can wrap a rope around the starter cup clockwise when you are looking at it. Choke the engine, check the gas is on, then give the rope a smooth pull. Should start the engine
