The driver springs are for rpm engagement. The driven spring controls how fast the belt starts it shift, holding low gear longer.
You CAN go too heavy on the driver springs and lose the ouuta the hole pull. If it starts to engage passed peak torq of the engine, this is less torq to the tires, it moves slower outta the hole, or less black marks on the pavement. All engines will peak torq at a certain rpm, finding that sweet spot can be tricky. I use the springs that leaves the longest black marks on the pavement, that's torq spinning the tires at a dead stop, not hp.
