pttm
Rusty.
Hey guys I was just wondering if 0.095 inches is a good aluminum circular tubing wall thickness (4 a yard kart frame). Thanks 4 ur help
on that note how do u weld aluminumDo you know how to weld alluminium? It is not the same as steel
Have not tried to weld aluminium tubing, but aluminium plates distort really easily by the heat of the welding
I was told to just spot weld (TIG) it. And go over it multiple times to get full seams.I was told to use a stitching gun with an arc welder to prevent excessive heat build up.
Havent seen one like that before.A stitching gun let's you lay down a continuous bead, with low heat/amps, and not distort the aluminum. IIRC, the gun pulses on / off, rapidly, allowing a continuous arc but keeping thermal build up to a minimum. I'll post a link in a few.... It might help the OP if he chooses to stick with aluminum, against the general consensus.....
EDIT I was close.....
http://www.eastwood.com/eastwood-stitch-welder-how-to-operating-instructions
