Millwright
- Messages
- 115
- Reaction score
- 28
Feeling a little skeptical tonight. Lol tough day at work.
I've read, and you tubed a bit about stock air filter setups being restrictive.
I've always doubted that these clone engines have been engineered to allow just the precise amount of air flow. To suggest that they are on the verge of being choked out, or simply underperforming?
Valve size, valve lift, duration, RPM, smallest choke point, and atmospheric pressure are the key players as I understand it.
Does anybody have any numbers or experiences to indicate that a stock engine, at 4500 RPM would really need, or benefit from a filter upgrade?
My air intake box has 4 inlet holes with a combined area of 2in²
Any other restriction would need to be smaller than 1.6" Diameter. I'm sure the throttle body is smaller. (upgrade carburetor?)
For the "stage 1" build, I'm thinking the jetting is the real hero. Filter upgrade, not so much.
Elimination of muffler, I can see the stock being restrictive, but I'm not sold on any big hp gain.
