3HP Crank in a 2.5HP Will it fit?
brendonv
Australia, Perth
My 2.5hp crank snapped and i got a spare 3hp that doesnt work, will a 3hp crank fit in the 2.5hp? There ends are the same size i no that its just the weights that im worried about, they may be to big and hit the crank when u turn it. Anyone know if it will fit?
Jerryburger
Admiral Annoy
The Nation's Catbox...er, AZ.
Are they B/S flattys? If so, check the model #s. The 60000 series motors had a shorter stroke than the 80000 series motors. I'm not sure if B/S made up the difference by either a taller deck height or a shorter con-rod length. Maybe it might be best to rob the goods off of the 2,5 to resurrect the 3 hp, if possible. I've ran the 60000 series and 80000 series motors in place of each other on different creations, and all other things being equal, the difference is very noticeable.
If you ever come across one of the B/S 3.5hp flattys, snatch it up. They have 9cu. in. displacement (vs 6 or 8) and are almost the exact same outside dimensions.
brendonv
Australia, Perth
The 3hp isnt rescueable, the block is fudged. Ill take it apart now and if the crank doesnt fit then o well.
brendonv
Australia, Perth
it fit btw guys. A 2.5hp and 3hp are the exact same, same piston, crank, cam, everything! The only difference is the carby.
