dwcopple
backyard hooligan
So the kart project I have has a welded 36 tooth rear sprocket, what will this be like if I use a 10 tooth #35 centrifugal clutch on a 5hp Briggs? Should I look for a 60 tooth that I can bolt or weld to the 36 tooth instead? The axle is not keyed and is solid stock
or I could run this jackshaft setup and down(?)size the front pulley on the crank of the engine and ditch the cent clutch idea
thoughts???
thoughts???
