careful...
make sure to NOT MESS up
the garter springs (drive
R springs) with
the coil spring (drive
N spring)
both come in different colors, so red spring is NOT nearly as telling as one might think here
let's be clear about that:
the driver springs (together with the weights since there are different weights too)
adjust the engagement of the driver (rpms of engagement and urge to to shift up)
the driven springs can't do much at all.. that's why there are less options in the first palce,
all they do is prevent upshifting for a period of time (or force);
the original can be set to three different values using the holes in the cam; (sometimes more or less holes.. most often three)
then a stiffer / weaker spring can take over if that's not enough.. but that's rarely ever necessary.
since effectively the rea wheel will help the driven spring to do it's job properly
the more load it sees the less chance the driver has to shift up.
So generally the green is what you should use 99.99% of the time.
Anyways, take care that you both talk about the same type of spring, otherwise you could run into troubles (buying something you won't ever need without getting what you wanted
