OPmini
moo
Ok here is my 2021 build off log. Im completely scraping this coleman, the frame has been shot to crap (it has snapped/ cracked in 8 different places). So I am scrapping the seat, engine, and tires. I am going to make a new HD frame out of all the steel tubing, flat steel, barstock, and square stock. I the new frame will look like the sketch I attatched to this post. It will have full suspension. I am also going to put a .308 cam in this engine. I have some larger shocks for the rear in the mail right now and I will also have to get some parts for the 40 series as it is broken. Im going to have a lot of machining done to the frame components (swing arm, front fork) Everything is going to be very thick steel tubing and the swing arm is going to be made out of solid 1in bar stock. The engine will be mounted dirtbike style with welded tabs securing it. I might tig weld some cooling fins onto the engine block aswell. Also, im tired of the dinky steering column screw shearing in half so im going to use a 1in grade 8 bolt with 1in id 2in od bearings
