2021 dui diy gokart
Karts of Kaos
the many mowers guy
Wisconsin
a little while back i got a new kart for $125 its not in the best condition and it definitely looked home made. it had 1 stick of rebar as a roll bar and its so short my 10yrol friend cant sit in it comfortably so it will be lengthened. i cut the rebar off and now im working on making it go. i forgot to take pics as i was going along but ill take some pics of it now i still have a lot to do. so far i bolted a pully to the drive wheel and put that engine on on. i am currently working on a clutch system thats what those springs are.
Karts of Kaos
the many mowers guy
Wisconsin
Here is the condition so far
Karts of Kaos
the many mowers guy
Wisconsin
so after i get the clutch system worked out i am planing on lengthening this kart, what it the safes way to go about doing that?
Bansil
Painter of gnomes....
Cut frame, measure I'd of frame, get tubing or solid that slides in, go 1-1/2 × diameter for length of plug per side plus wall thickness.
Example if 1-1/2 × 1/8 tube make slugs 4.625 long, this allows 1/8" gap. Drill a couple 3/8 diameter thru holes in the frame parts. Insert slugs, then plug weld 4 holes, slid other frame end on, leave 1/8 gap, plug weld and then finish off welding gap which will weld all 3 pcs of joint.
Does that make sense? If not I can do a ms paint in morning
Karts of Kaos
the many mowers guy
Wisconsin
so at the moment the clutch system i have it using is a door hinge and some springs to actually tilt the engine, but i think that that moves to much from the engine acceleration so i am going to make a normal style clutch with an arm and a moving pulley. but i there probably wont be any updates for a little while.
OPmini
moo
Phoenix, Arizona, United States
wait... you're using an actual door hinge??? Pictures please lol
gegcorp2012
Alabama
I used to ride a cart with the (belt is the clutch) tilt the engine system. AFAIK, that was a production kart from a store like Western Auto.
Karts of Kaos
the many mowers guy
Wisconsin
well i took it back apart bc you would need the springs to be much stronger than if you were just using a tensioner arm like on a snow blower. and also whenever the engine accelerated it would bounce around a lot so i am not going to go with that design.
Karts of Kaos
the many mowers guy
Wisconsin
ok so i planned on extending the frame but i was able to just but a different seat on it and move it back. i also started on make a clutch system but it need some adjustments. ill send pic soon
Karts of Kaos
the many mowers guy
Wisconsin
soo i probably wont finish this before the end of the year bc ive got a lot of school and alot of other projects that i need to do first. but im thinking of turning it into a live axle kart using the drive train from a rototiller.
