Hello DIY People;
Hydraulic brake rotor install, the kart is design for two motors so I did a motor set up to locate the brake rotor. I wanted to put a seven inch rotor on the right side, but no room, good place for a right side drive motor but that is not available. So I ended up with a 6 inch rotor under the right side motor. built the bracket holding the caliper using a card board cut out, on to 3/16 steal plate, mark, fab, fit, clamp, hold, and weld. piece of cake.
