2019 - Buggy DR600
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
Hi everyone
This is my entry for 2019, but I will not finish it this year, hopefully for next year...
The plan is to build two seater with 5 speed motorcycle engine, independent suspension..
Engine donor is Suzuki DR600 and for suspension parts I used seat Ibiza...
For frame, plan is to use 5/4 tubing..
JTSpeedDemon
2019 Build Off Winner!
Texas
Very interesting....
It'll probably be a beast when it's done(Probably want to upgrade to front discs IMHO).
Good luck on this multi year spanning build!
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
yes, regardnig front brakes, I just sawp front and rear from the car to the buggy..
it would be best to find another car to take discs...
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
while still waiting for some parts , not much progress..
only disassemble one drum brake ..
I think , it would be easy to make upright and bolt spindle (drum) on it ..
gegcorp2012
Alabama
Hi @karte_m0lim,
I like those long travel shocks and springs.
So the rear (Ibiza) will be on the front (buggy) and the front (Ibiza) will be on the rear (buggy). Yes?
I will be watching to see how you make the steering on the new front wheels, or will this be rear wheel steering ??
Sent from my SM-J700T using Tapatalk
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
Hi @karte_m0lim,
it stock car shocks .. not sure how it will behave on buggy..
plan is to put original rear shocks again on rear and already bought small simple shocks on front ..
yes.. it looks simple to do with basic tool ...
no rear wheel steering, normal steering .. will use stock steering assembly (steering wheel, steering column, H - joints and steering rack ) ..
car itself didn't had servo so it make things simpler ..
only problem is that rack is too long, 60 cm, and I am afraid that chassis on front will be too wide causing A-arms to be short as well as suspension travel ..
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
not much progress over the weekend as some parts arrived, something was sent wrong, something I order it wrong..
so only front spindles ...
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
so far this weekend :
- hubs for sprockets and jack shaft
- motorcycle teared a part
- bottom frame
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
not going to use motorcycle frame.. its there just temporary ..
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
finally parts arrived...
bearings 35 mm , sprockets ..
40 tooth goes on axle and 20-24-28 tooth for JS exit ..
so with easily swap will have top speed of 60-80-100 km/h...
small sprocket (14 tooth) is for chain tensioner ...
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
not much done this weekend ..
- assemble rear axle and sprocket ...
- drill new sprockets for JS
- shortened steering rack
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
