Well let me give an update as to what we've done in the first month:
- pressure washed all the grease and grime off
- disassemble almost everything.
- take the wheels apart and found the balls falling out of the bearings when we took the axle nut off.
- straightened the frame with the help of a torch and some giant pry bars.
- cut off front spindles (going to replace them with larger ones with the spring under the axle for a bit of suspension)
- stripped old floor graphic from the pan. TIP - use a heat gun and quality thick putty knife and it can make your life light years easier
- started to design and mock up extra roll cage (with pvc)
-stripped paint off wheels and various suspension parts
UP NEXT:
- weld some gussets on the front axles
- fabricate roll cage
Sent from my SM-N950U1 using Tapatalk
---------- Post added at 10:04 PM ---------- Previous post was at 10:03 PM ----------
I wanna know more about the PVC. Mock up? Or Intake Snorkel? Or???
Mock up roll cage. See most recent posts and it's more clear in those pics.
HOWEVER, I think you may be on to something with the snorkel idea!
