Hey all! New to forum. I picked up a razer dune buggy for $40 bucks with the intention to upgrade for my 12/13 year old kids. I had a 36v 1000w motor I took off an electric minibike, and purchased a 36 v 16ah battery pack. When installing, felt it was a tight fit with the jack shaft so I took it off. If I remember right new motor has 12 or 13 tooth sprocket so slightly bigger than original 350watt motor. Also put 10" tires on rear. Anyways, between removing the jack shaft and upping gear ratio, the thing of course flies...once it gets going. Common problem right? Top speed or torque...choose one. Anyways, when thinking through my options to get some torque back, I came across dual sprocket centrifugal clutches that give 2 speeds on some minibikes. They seem to engage at around 2900 RPM.
My questions are:
1) Would it be possible to use one of these on an electric motor?
2) Would it achieve the goal of reintroducing low end torque, assuming the first gear was paired to a bigger axle sprocket) while maintaining topend speed?
3) Is there a better way (specific to electric motors) to achieve same goal short of simple getting a huge motor/controller that draws lots of amps?
4) Rather than just a rpm based clutch, is there something like this that can be engaged at will?
Before stumbling across this I was also toying with the idea of having 2 motors on same axle with different gearing, both with freewheel sprockets so that when not engaged, they would just spin freely, and then coming up with some way to switch power between the 2 motors as a way of changing gears. Not sure of the feasibility of something like this and it's an expensive experiment!
TIA! My goal is to learn on this one and then build out better one on a adult sized chassis (or start from scratch).
My questions are:
