winnn420
If someone knows more about this kart that I'm trying to bring back from the dead, please feel free to share. From what I can find online and going by the current components and numbers stamped on the chassis, it's a 1999 Red Barron that was made by CRG/Kali Kart. Someone at Accelerationkarting told me it's a CRG after I gave them the numbers stamped on the chassis. The F&R brakes are identical to CRG ven99 brakes but they have R.B. etched into them which I haven't found on any other CRG brakes. I purchased all of the seals for CRG ven99 brakes and they are a perfect fit. There were two "Red Barron" decals on the front of the chassis, apparently CRG made karts for Red Barron in the late 90's but I can't find anything online about them. I'm only able to find one other picture online of the exact same chassis, and the owner is pretty much just as clueless about his as I am about mine.
I got it with a running 1998 KX125 engine for $450 because the previous owner wrecked it into a curb, and the chassis did appear to be useless. Also the brakes were badly in need of a total rebuild but they're now ready to be re-assembled and installed. I chopped off the bent lower front bumber, replaced the front upper bumper and will probably have a new lower bumper welded back on. I'm sure it won't be a race kart ever again but it will make a good play kart. I'll be sure to take more pics than I have been.
The parts I purchased so far are:
new tie rods & tie rod ends
front upper bumper
spingle king bolts & bearings
brake seals, shims & missing hardware
exhaust gasket
throttle & clutch cables
throttle return springs
header wrap for exhaust
& plenty of other misc hardware
Here is how she sat when I bought her...
front upper bumper
exhaust gasket
