1973 honda cb750
Karts of Kaos
Wisconsin
yesterday I got a motorcycle! I cot a honda with a cb750. the motor is seized and has been out in the weather for a long time. the handle bars are broken, the shifter arm is gone, and so is the clutch trigger,there are no valve cover bolts but the valve cover is there. the front break is hidrolic and the hose is cracked. the rear brake is a drum brake and is functional. in total I payed 50$. i will post pics soon.
JTSpeedDemon
2019 Build Off Winner!
Texas
Hopefully that lock is as simple as a stuck clutch, but that bike may very well be more trouble than it’s worth. That said, go for it! If it ends up running well, you may have a good flip project or even the occasional around town ride!
Obviously, if you get to ride it, don’t hurt yourself.
Also- just remember parts are a lot more pricey than a 212 :roflol:
Anyhow, a seventies CB750 Honda is a great bike, and it's a bulletproof engine,
good for well over 200k miles easily.. even mistreated it certainly outlasts quite a few of it's competitors.
You can still buy almost every part of that engine, some bike specifics are harder to find (seats, fairings and such),
and restoring it (the BIKE! not just the engine mind you) will certainly be worth the effort.
frankly, for 50 bucks.. I'd buy all Hondas I could find just frame, engine, wheels and tank not running IDC...
that's a steal,
waiting for pics :D
Karts of Kaos
Wisconsin
oh yeh, i forgot to say it only has 27,794 miles. here are the pics.
and JT I am fairly sure that the pistons are seized because it was left out without spark plugs. it vary well may have a seized clutch too
Karts of Kaos
Wisconsin
today I got the engine out (not an easy prosses I might add.) and I wanted to take off the heads, but I can git the timing chain off . How do I do that with a seized engine?
Karts of Kaos
Wisconsin
that's a steal,
waiting for pics :D
and yes sid I am planning to restore the whole bike
unfortunately a CB750C bike I'm personally not a fan of those soft-choppers at all
I like the original CB750 four much better but that's just personal taste..
Still the engine is great, only 67 horses but gives you all the torque you need in a bike,
Again for 50 bucks.. it's a steal.. too bad I don't see any tank ..
those can get expensive quite quickly (if in good condition)
and worse the carb manifold flanges are also missing it seems...
that will not only be rather expensive but also not exactly trivial to find,
too many different generations and too many wrong info on offers for motorcycle parts to be sure :(
So chances are you end up with a non fitting manifold.
take great care to pick the right set,
Ideally find the original Honda workshop manual and partslist first.
Karts of Kaos
Wisconsin
thanks Sid, I do have the tank and it is in great con ditio0n on the inside and only has surface rust on the bottom of the tank. it just did not come mounted. same with the headers and exhaust. I just refer to it as a "a bike" but what is the difference between the 750 four and the soft chopper?
Yes, that's a good deal for $50.00 :)
.,..but, it looks like you have lots & lots of work ahead of you :unsure:
Have you thought about converting it to electric? :popcorn:
My 1980 Kawasaki 440 LTD had a seized engine when I got it
...& now it has an 8,000W motor :cool:
It has lots of torque
...& is super fun to ride :sifone:
Karts of Kaos
Wisconsin
I'll consider it FA thanks for the idea. so on Sunday I pulled the heads and well it was rely bad, especially on the #1 and #4 cylinders. so I cleaned it out and put some evapore rust in it and I am waiting for results.
Karts of Kaos
Wisconsin
here are some pics of the cylinders. the punch is for scale to show how much stuff there is.
JTSpeedDemon
Texas
YUCK! I think that might be a bit too far gone, but you might be able to get it bored out......*maniacal laughter
