1972 arctic cat panther 340
Karts of Kaos
the many mowers guy
Wisconsin
so today i picked up a 1972 arctic cat panther with a 340 cc engine in it and a separate parts engine. I am having a problem with the spark. when the kill switch is plunged in one calendar has spark and when I unplug it both have spark. when I push the kill switch neither have spark. when is it that only one calendar has spark?
Karts of Kaos
the many mowers guy
Wisconsin
well I figured out something, one of the points is stuck open and seems to be mangled. apparently I spoke too soon it does not have spark on the problem cylinder. i was just seeing if I would get shocked. how do I get the flywheel off. I try to make a puller but i broke a bolt when I tried to use it.
JTSpeedDemon
2019 Build Off Winner!
Texas
Pics man! We need pics! :roflol:
Also it took me a little to figure out what you meant by "calendar".
Karts of Kaos
the many mowers guy
Wisconsin
sorry. I will post picks later. for those who did not figure it out I meant cylinder. to day I picked up a gear puller ad I still could not get off the flywheel . I will keep trying tho
Karts of Kaos
the many mowers guy
Wisconsin
here are the pics sorry they are up side down I forgot to take them in landscape.
Karts of Kaos
the many mowers guy
Wisconsin
well I found out why the fly wheel was so hard to get off. There was a starter ring. I ended up pulling it off the flywheel. I have the little pin. ho do I go about putting the gear back on, or do I even have to.
Karts of Kaos
the many mowers guy
Wisconsin
when I pulled the flywheel I did not realize that I needed to take the cover off and the starter gear got stuck on the case and came off. I did not know there was a starter gear because there is not a starter.
I did not put the starter gear back on but I put the flywheel back on and fixed the pints. I used some 20 to one in a zoom bottle put it into the carb and the engine ran! one major problem is that the tc wont engage. How can I fix that?
Did you get it up to speed to get the CVT to engage? These don't engage until like 3000rpm or so.
Karts of Kaos
the many mowers guy
Wisconsin
sorry i meant disengage. but I figured it out and now I have to put it back together. there is a piece that has 3 prongs and goes under the rollers. how do I put it back on do i need a special tool
What brand is the CVT and does it have a model number. Trying to see if it was a Comet or some other brand. Looks like if it was a Comet, it'll be stamped on the driver. Looking for some sort of diagram or manual for it or the sled.
Karts of Kaos
the many mowers guy
Wisconsin
thanks I will go check
---------- Post added at 08:00 PM ---------- Previous post was at 07:49 PM ----------
I could not see if it was a commet tc but it said made in la, California. the number on it were 146400 and 100 347
---------- Post added at 08:06 PM ---------- Previous post was at 08:00 PM ----------
it is very similar to this one
---------- Post added at 08:20 PM ---------- Previous post was at 08:06 PM ----------
I think it is a clone tc. I watched this video and noticed that mine has the same nut retainers.
Best guess I can find is the Salsbury 910. It has a similar design to the 780. Found an article talking about the Panther, it having a 4 stroke 8hp Kohler engine, Sachs 303 rotary engine (surprisingly popular back then), Kawasaki 440, the 340, and a 399. https://snowgoer.com/top-stories/flashback-the-1972-arctic-cat-panther/26641/
I'm just making an assumption based on the article that yours is a 910.
Karts of Kaos
the many mowers guy
Wisconsin
here are some more pics
I tried looking for a service manual last night, came up empty handed. You may have to go to a power sports dealer and buy one through them. I'll look again in like 5 hours when I'm on my lunch break and have more time to look.
Karts of Kaos
the many mowers guy
Wisconsin
got the tc back together with some help from my dad. to day I am going to start cleaning out the inside of the snowmobile. when I fired up the engine the tc was a little chunky returning. what does this mean?
Karts of Kaos
the many mowers guy
Wisconsin
welp,I have been doing alot of work on it recently and discovered that I will nee to get a ne center sel. so I am planning to swap to my spare engine and hope that that one does not need a new one.
