110cc atv engine question
RandomK
I'm going to be making a go kart with a 110cc atv engine from a taotao quad with neutral and reverse....how can I make this engine has powerful as it can be?
RiotKart
Im in the process of doing the same - Honda atv 110 4 speed semi automatic no reverse... to my surprise the smaller the sprocket on the rear axle the faster the kart went. Right now with a 6 inch tire the size of sprocket on axle is the same size as sprocket on motor 14 tooth. I started off with the large sprocket on rear axle like you see on mini bikes and 4th gear would get it to barely move. What i got now 14 motor 14 axle and i never have to take it out of first gear it goes so fast...
Smerft85
Southern Colorado
That's because you are geared way too high! Gear it down with a larger sprocket then you can use the gears how they were intended. I bet it is blistering fast, but takes forever to get there right?
RiotKart
Well it wont do a burnout but gets up and moves fast. by the time I shift to second gear its going scary fast. Now I dont know how to ca;lculate the gearing for the best ratio all I have is what I experienced The Atc 110 motor I put on the go Kart came off the Honda 3 wheeler. So my first thought was to use the 3 wheelers rear sprocket which I did and first gear I would have to rev up the rpms to full throtle to get it to move. second gear same thing full throtle moving at 5 mph. 3rd gear a litle better... The 3 wheelers sprocket is 3 to 4 times bigger than the one i got now.
Smerft85
Southern Colorado
Drop the tooth count on engine side and increase the axle teeth. I don't see any reason this wouldn't apply for your one rig when everything else is set up like that?
RiotKart
I will give it a try... Maybe it will do a burn out that would be great
Smerft85
Southern Colorado
I have no idea what your tire size, rider and machine weights are, which engine you have or anything, but for example I've got a 10t sprocket on most of my engines weather they be a centrifugal clutch or t/c setup, and usually a 60t on the axle if using #40/41 chain, typically they have a good torque to top end speed ratio, and I'm running either 15" or 18" tires, about 160 pounds for me and maybe 200 on the machine. I can cruise around 45 mph, can drift and do doughnuts on dirt, and will break the back tires loose on loose ground, or pavement in a power turn. I have noticed the engine sprocket can be a bigger factor per tooth than an axle sprocket too, a 10t will be more torquey than a 12t for example. Typically we start at a 6:1 ratio based on tire size and sprocket sizes, only thing I question about that ratio is the fact you are running a transmission, likely will have a different effect than just a horizontal shaft Honda/clone.
