gegcorp2012
I am installing a Mikuni clone (a Chikuni) on my Predator 212 and am about to hack my throttle cable. What's the best way to keep from cutting my existing cable (that I paid $ for) so short ?
Is there a way to use a short piece of cable inside the carb and put some kind of adjuster block or coupling at the top of the cable guide from the carb to connect to the foot pedal cable ?
My cable has a flat spot (from stock set screw and linkage) right in the area where the cable would be sliding through the bent tube at the top of the new carb if I snug it up to the end of my existing cable.
Also, my throttle cable is kind of heavier gauge than what I remember seeing on a Mikuni back in my Mini Trail 50 days.
Photos or parts list of how you did your conversion would be appreciated.
